Opt fragment type in sequence diagram?
Hi there!
I’m currently in the process of setting up a sequence diagram but I’m a little stuck. It seems that SDE supports some fragment types but I was unable to spot the “opt” type. I did find the “alt” type which basically portraits an if … then … else … situation but right now I’m looking to add a mere optional part in my diagram. So, an “opt” fragment type with no further “else” conditions.
I was kinda hoping that the “frame” element would allow me to define an opt frame but that isn’t going to work out :wink:
So my question basically is if its possible to setup an opt frame right now. And if thats not the case if its possible to add this functionality somehow ?
With kind regards,
Peter Looyenga
Hi Peter Looyenga,
Thanks for your post. You can right-click on created “alt” fragment and select Operator Kind > opt in the popup menu. Operator Kind can be selected in fragment’s specification dialog as well.
voilaa… thanks so much. even I was thinking hw to make out the opt in visual paradigm… :slight_smile:
hi! same question but to use on the online version. I cant see that option by right clicking…
With loop elements the same happens, i dont find them. Is there any complete tutorial of the online version for sequence diagrams?
Hi Fiorella,
It is available in the Format Panel upon selecting the combined fragment:
Best Regards,
Antony.
Here is a video showing how a simple sequence diagram is drawn using VP Online:
You can find many more videos for VP Online in our YouTube channel:
Hope this helps,
Antony.
