Process Map - font size
Hello
It’s possible to change font size in Process Map diagram?
obraz
Not to my knowledge. You can right click and then use “Format map…” to customize some options such as the color of the labels, space between them as well as the size of the cells (the ones which contain the summary data) but other than that doesn’t seem possible.
If you want this level of customization then I think you’re better off using the Customer Journey Map diagram:
One small caveat though is that this diagram type is only available in the Professional edition (and up).
Hope this helps!
Thank you for your response.
The Customer Journey map has the same modification capabilities as the Process Map, I think it’s the same engine :slight_smile:
It doesn’t.
Process map uses the web engine whereas Customer Journey is a regular diagram using the standard (offline) engine.
