I’m trying to register Visual Paradigm 16.3 build 20210803 on my Windows 64bit machine and getting the following error:
from searching over the internet and on this forum I found another thread with the same issue, in which the guy installed another JRE on his dev machine as I did.
I removed the other JRE, set the JAVA path to the bundled one, and tried to follow the solution but could not manage to get this to works
Registration: Failed to connect to Visual Paradigm servers.
Here is the VP logs:
[2021/05/31 15:29:27] [message] [Mon May 31 15:29:27 IDT 2021]: Start Visual Paradigm [VP]: 16.3 (20210517) [2021/05/31 15:29:27] [message] Operating system: Windows 10 10.0 running on amd64 [2021/05/31 15:29:27] [message] Java VM: 11.0.10 OpenJDK 64-Bit Client VM, vendor 11.0.10+9 AdoptOpenJDK [2021/05/31 15:29:27] [message] User: Tomer.Ha, language: en [2021/05/31 15:29:27] [message] Installation ID: 11bd5f123b387ab76b6a418bdd588d77 [2021/05/31 15:29:27] [message] Memory: current=247M, max=989M [2021/05/31 15:29:28] [message] start startup getLicenseKey on 31-May-2021 [2021/05/31 15:29:28] [message] getLicenseKey in local ... [2021/05/31 15:29:28] [message] finish startup getLicenseKey [2021/05/31 15:29:28] [message] getVerifiedLicenseKey: null; state=Installed [2021/05/31 15:29:43] [warning] javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:131) at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:349) at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:292) at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:287) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:654) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(CertificateMessage.java:473) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(CertificateMessage.java:369) at java.base/sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:392) at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:443) at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:421) at java.base/sun.security.ssl.TransportContext.dispatch(TransportContext.java:182) at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:171) at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1408) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1314) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:440) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:411) at java.base/sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:567) at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:197) at java.base/sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1367) at java.base/sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1342) at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:246) at v.bzj.bi.a(:124) at v.bzj.bi.a(:80) at v.cfk.af.a(:1384) at v.avg.fx.a(:1278) at v.cfr.de.a(:421) at v.cfr.co.w(:394) at v.cfr.cu.actionPerformed(:108) at java.desktop/javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1967) at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2308) at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:405) at java.desktop/javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:262) at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:279) at java.desktop/java.awt.Component.processMouseEvent(Component.java:6635) at java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3342) at java.desktop/java.awt.Component.processEvent(Component.java:6400) at java.desktop/java.awt.Container.processEvent(Container.java:2263) at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5011) at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321) at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843) at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918) at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547) at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488) at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307) at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2772) at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843) at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772) at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721) at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95) at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745) at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85) at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742) at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203) at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124) at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:117) at java.desktop/java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190) at java.desktop/java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235) at java.desktop/java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.desktop/java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233) at java.desktop/java.awt.Dialog.show(Dialog.java:1070) at java.desktop/java.awt.Component.show(Component.java:1716) at java.desktop/java.awt.Component.setVisible(Component.java:1663) at java.desktop/java.awt.Window.setVisible(Window.java:1031) at java.desktop/java.awt.Dialog.setVisible(Dialog.java:1005) at v.avg.gb.b(:790) at v.avg.gb.a(:604) at v.avg.gc.a(:615) at v.avg.gc.call(:612) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:313) at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770) at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721) at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85) at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740) at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203) at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124) at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113) at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109) at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:439) at java.base/sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:306) at java.base/sun.security.validator.Validator.validate(Validator.java:264) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:313) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:222) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:129) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:638) ... 83 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126) at java.base/java.security.cert.CertPathBuilder.build(CertPathBuilder.java:297) at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:434) ... 89 more
Many thanks in advance
