[2019/05/29 10:27:47] [message] [Wed May 29 10:27:47 BRT 2019]: Start Visual Paradigm Community Edition [VP CE]: 15.2 (20190501)
[2019/05/29 10:27:47] [message] Operating system: Linux 4.19.42-1-MANJARO running on amd64
[2019/05/29 10:27:47] [message] Java VM: 1.8.0_212 Java HotSpot(TM) 64-Bit Server VM, vendor 25.212-b10 Oracle Corporation
[2019/05/29 10:27:47] [message] User: henrique, language: pt
[2019/05/29 10:27:47] [message] Installation ID: 933fd0183f65cb549983202a436a6b9f
[2019/05/29 10:27:47] [message] Memory: current=245M, max=455M
[2019/05/29 10:27:47] [message] start startup getLicenseKey on 29-mai-2019
[2019/05/29 10:27:47] [message] getLicenseKey in local ...
[2019/05/29 10:27:47] [message] finish startup getLicenseKey
[2019/05/29 10:27:47] [message] getVerifiedLicenseKey: null; state=Activating
[2019/05/29 10:27:47] [message] Workspace: /home/henrique/.config/VisualParadigm/ws
[2019/05/29 10:27:49] [message] Opening Project: /home/henrique/.config/VisualParadigm/ws/.vpprefdata/.systemproject.vpp
[2019/05/29 10:27:52] [message] Cannot write to folder: /usr/share/visual-paradigm-community/bin (Access is denied)
[2019/05/29 10:27:52] [message] Cannot write to file: /usr/share/visual-paradigm-community/bin/Visual_Paradigm_Fixed.vmoptions (Access is denied)
[2019/05/29 10:27:55] [message] Opening Project: /home/henrique/Desktop/Finaxis/Arquitetura/Geração Automática VI/apiTransferenciaVIautomatizado.vpp
[2019/05/29 10:27:57] [message] Open Project "/home/henrique/Desktop/Finaxis/Arquitetura/Geração Automática VI/apiTransferenciaVIautomatizado.vpp", Time Used: 2 seconds, Memory: 337.0 MB (353370112), Project File Size: 681.0 KB (697344), Diagram Count: 1
[2019/05/29 10:28:18] [message] mai 29, 2019 10:28:18 AM java.util.prefs.FileSystemPreferences checkLockFile0ErrorCode
ADVERTÊNCIA: Could not lock System prefs. Unix error code 0.
[2019/05/29 10:28:18] [message] mai 29, 2019 10:28:18 AM java.util.prefs.FileSystemPreferences syncWorld
ADVERTÊNCIA: Couldn't flush system prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
[2019/05/29 10:28:18] [warning] javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at sun.security.ssl.Alerts.getSSLException(Alerts.java:208)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1903)
at sun.security.ssl.SSLSocketImpl.handleException(SSLSocketImpl.java:1886)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1402)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1334)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1309)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:259)
at v.byz.bb.a(:124)
at v.byz.bb.a(:80)
at v.cfa.x.a(:1379)
at v.aux.fp.a(:1265)
at v.cfh.de.a(:421)
at v.cfh.co.w(:394)
at v.cfh.cu.actionPerformed(:108)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233)
at java.awt.Dialog.show(Dialog.java:1084)
at java.awt.Component.show(Component.java:1671)
at java.awt.Component.setVisible(Component.java:1623)
at java.awt.Window.setVisible(Window.java:1014)
at java.awt.Dialog.setVisible(Dialog.java:1005)
at v.aux.fo.b(:1092)
at v.cfa.e.run(:187)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Caused by: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at sun.security.validator.PKIXValidator.<init>(PKIXValidator.java:91)
at sun.security.validator.Validator.getInstance(Validator.java:181)
at sun.security.ssl.X509TrustManagerImpl.getValidator(X509TrustManagerImpl.java:318)
at sun.security.ssl.X509TrustManagerImpl.checkTrustedInit(X509TrustManagerImpl.java:179)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:192)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
... 72 more
Caused by: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
at java.security.cert.PKIXParameters.setTrustAnchors(PKIXParameters.java:200)
at java.security.cert.PKIXParameters.<init>(PKIXParameters.java:120)
at java.security.cert.PKIXBuilderParameters.<init>(PKIXBuilderParameters.java:104)
at sun.security.validator.PKIXValidator.<init>(PKIXValidator.java:89)
... 84 more
[2019/05/29 10:28:22] [message] Cannot write to folder: /usr/share/visual-paradigm-community/bin (Access is denied)
[2019/05/29 10:28:22] [message] Cannot write to file: /usr/share/visual-paradigm-community/bin/Visual_Paradigm_Fixed.vmoptions (Access is denied)
Should I run VP as sudo, change permission or is it something else?
If I run as sudo, it works perfectly: I can register VP, but if I run it as normal user again, it still prompts me for activation. The results are the same as the orignal ones.
It seems related to your JRE. We bundled a JRE (/home/kit/daily_clean/Visual_Paradigm_CE_15.2/jre/bin) and should be used by default. Did you changed to your JRE? Can you try the bundled JRE?
It should be the problem of your JRE.
Can you try this workaround by added “-Djavax.net.ssl.trustStore=/etc/ssl/certs/java/cacerts.” JVM option? https://bugs.archlinux.org/task/55717
