I’m evaluating VP Enterprise, and I already have a Subversion server, but I’m not able to get anything out of the Teamwork Client in Visual Paradigm.
I can login in the Subversion server and check in and out projects, but then I cannot update or commit. It complains “cannot export svn://taserverlx/progettazione/prova UML/Anagrafe Edilizia v 1861”.
The help pages always show a http:// Subversion server, whereas we have a svn:// one. Maybe this is a problem?
Restart the application
Note:
Hi Jick.
unfortunately there was only a light improvement with your patch.
The update still refuses to work, complainig as before.
The commit now opens a progress window, but it hangs pretending to progress…
I stopped it after 10 minutes without anything changed.
The only thing that works is import and initial checkout.
I tryied it on a Linux installation (RedHat Enterprise linux AS 4) and a Windows XP installation. Everything is the same.
Subversion is version 1.3.0 on the server and on every client.
The Java Virtual Machine on the clients (where I installed Visual Paradigm UML) is version 1.5.0_07.
Thanks for your reply. Wow, the log are too big. Would you mind deleting them and then reproduce the problem to obtain a log file that is smaller in size? Thank you in advance!
Do you have a Windows machine that can run VP and can connect to the server? If possible, we would like to hold an online meeting with you to take a look at this problem. However, the meeting software supports only Windows OS.
It is now 16:12 in Hong Kong. Let’s have a meeting at 14:00, your time. Is it ok? You no need to install any application for the meeting beforehand. I will send you the information at that time. (Of course, I suppose you have installed VP-UML ;-))
14:00 Italian time should be 20:00 Hong Kong time.
It’s better to read and write, and not to speak, as long as my spoken English is not so good.
See you later.
Vito
[quote=Jick]Hello Vito,
