20210514
- Enhance performance on purge project in Teamwork Server.
- Fixed bad layout issue in Teamwork Client dialog under GNOME GTK+.
- Fixed code generation problem under IntelliJ IDEA integration.
- Fixed cannot add row to Customer Journey Map and Process Map issue.
- Fixed sequence diagram element misplaced when distribute horizontally issue.
- Fixed generate update database script for SQL Server always generate alter statement on time columns issue.
- Fixed unable to configure floating license access code issue.
- [VP Online] Fixed shape disappear under print preview.
20210701
- Support import BIAN ArchiMate XML models.
- Fixed missing getter/setter on diagram ID operations in plugin API issue.
- Fixed database reversing wrongly handle drop procedure as drop function issue.
- Fixed Teamwork Server unable to import license key due to non-supported system time format issue.
- Fixed VP Server installation unable to setup embedded database issue.
- Fixed incorrect model order when sort by name issue.
- Fixed missing content problem in generated swagger code.
- Fixed unable to delete task dependencies in Tasifier issue.
- Fixed screen capture tool not working on Windows issue.
20210801
- Support C4 Model in Modeler Edition.
- Support specify resolution when export Customer Journey Map and Process Map into images.
- Support SysML DirectedFeature.
- Enhance completion message on REST reverse engineering.
- Enhance import BIAN ArchiMate XML models.
- Fixed issue on wrongly delete column from view when column is duplicated from another entity.
- Fixed missing empty space between text issue in Doc. Composer output.
- Fixed problem on import project from XML format.
- Fixed search not working in Story Map and User Stories issue.
- Fixed Doc. Composer generate incorrect requirement ID issue.
- Fixed ETL table display incorrect requirement ID issue.
- Fixed text spacing issue in Doc. Composer.
- [VP Online] Support remove floating license key.
20210821
- Support show from on SysML diagram.
- Support create Constraint Properties in SysML Block.
- Support show time trigger in state transition.
- Enhance diagram overview shape to support display diagram name in SysML format.
- Enhancement on SysML view, viewpoint and stakeholder.
- Enhance MySQL database generator wrongly apply max length checking on varbinary issue.
- Fixed java.lang.ArrayStoryException when commit project issue.
- Fixed content in text box not fully shown in Doc. Composer issue.
- Fixed missing description in attributes when reverse engineer from JSON issue.
- Fixed fail to import Swagger to model issue.
- Fixed fail to export data to Excel issue.
- Fixed mis-ordered project internal properties causing unable to commit project problem.
- Fixed Project Publisher wrongly publish column description in summary table issue.
20210911
- Support configure to display constraint name or value on diagram.
- Enhance Internal Block Diagram by support reuse properties from its parent Block.
- Enhance display of diagram name according to SysML format.
- Fixed model folder being duplicated problem.
- Fixed unable to select Story Map structure issue when re-create agile process.
- Fixed wrong icon for ArchiMate Realization, Specialiation and Flow connectors in legend issue.
- Fixed call behaviour wrongly moved under action issue.
- Fixed cannot load VP Online diagram in Teamwork Server issue.
20210928
- Fixed export entity to Excel missed stereotype models problem.
- Fixed permission access problem on PostMania.
- Fixed problem on unable to save VP Online type diagrams when using local workspace.
- Fixed wrongly allow adding freehand shape to legend issue.
- Fixed fail to generate DDL due to entity without column issue.
- Fixed associations not being show in specification dialog problem.
- Fixed fail to reverse OpenAPI file with additionalProperties issue.
- Fixed C4 diagram only show small editor issue.
- Fixed missing icon for Parts in Model Explorer tree issue.
- Fixed reverse SQL Server DDL losing datetime2 column type issue.
- Fixed Copy Dependency in SysML Requirement Diagram unable to copy requirement text issue.
- [VP Online] Fixed corrupted PNG image being exported issue.
20211001
- Support auto generate SysML PrimitiveDataValues to project.
- Support repair project with remove duplicated models.
- Fixed word wrap problem on SysML Block.
- Fixed drag & drop Property to Block created double elements issue.
- Fixed plugin API cannot generate diagram in headless mode issue.
- Fixed order of Requirement property not create according to configuration issue.
20211012
- Enhance Teamwork Server & VP Online support showing project relative path according to folder structure.
- Enhance handling of EoF during database reverse engineering.
- Fixed activity unable to fully render element caption under specific zoom ratio issue.
- Fixed unable to drag & drop nested properties to Internal Block Diagram issue.
- Fixed missing support “as” syntax in reverse engineering of SQL Server DDL issue.
- Fixed wrong tooltip on ArchiMate Application Collaboration element issue.
- Fixed Apply button in Configure Code Type not immediately apply change to chart issue.
- Fixed unable to duplicate sequence diagram models with loss/found message issue.
- Fixed text element losing leading space on Mac issue.
- Fixed unable to handle “anyOf” in REST reverse engineering issue.
- [VP Online] Restore find and replace buttons in new user interface.
20211014
- Enhance Teamwork Server prompt message for user try to create new member when server is using LDAP/AD/SAML user authentication method.
- Enhance Teamwork Client support search on branches when perform switch and merge of branch.
- Fixed Mindmap node add comment resource button being overlapped issue.
- Fixed unable to save project to local device even not using any web based features issue.
- Fixed unable to import VP Online diagrams to VP desktop application issue.
- Fixed Instant Reverse of Python unable to handle metaclass inheritance issue.
- [VP Online] Fixed z-order problem on editing diagram.
- [VP Online] Fixed connector not being relocate when resize multiple connected elements at the same time.
20211109
- Fixed missing support full port compart in SysML Block issue.
- Fixed filter box in open project dialog unable to search on existing checked-out projects issue.
- Fixed list view in open project dialog wrongly activated under display search result issue.
- Fixed find & replace text damage text layout in model description issue.
- Fixed Doc. Composer missing default templates for BMM process issue.
- Fixed Doc. Composer missed output entity name when report transition relationship to column issue.
- [VP Online] Enhance connector selection on diagram.
- [VP Online] Fixed video chat bar overlapped with diagram’s bottom menu issue.
- [VP Online] Restore sweeper and magnet buttons in new user interface.
- [VP Online] Fixed problem on embedded artifacts to HTML.
20211114
- Fixed unable to open VP Online diagram in VP Desktop issue.
- [VP Online] Fixed missing rotate image in collage problem.
- [VP Online] Fixed export artifacts to PDF generated extra page issue.
- [VP Online] Fixed unable to open artifacts from device issue.
- [VP Online] Fixed cannot apply font to text problem.
20211131
- Enhance performance on generate business process simulation charts.
- Enhance Integer() constructor to fulfil JDK 11/17 requirement in generated ORM code.
- Support show constraint expression on diagram.
- Fixed empty EPS file being exported from diagram issue.
- Fixed UML activity not fully apply font colour issue.
- Fixed wrong license check issue on output Customer Journey Map and Process Map to document.
- [VP Online] Support alignment guide when resizing elements.
- [VP Online] Enhance user interface on sharing of artifacts.
- [VP Online] Fixed unable to paste content to diagram name box using Ctrl + V shortcut problem.
- [VP Online] Fixed unable to save diagram problem.
